group pattern with parameter
   4464   5   2
Could use parameter channel in group pattern?
I tried @P.y>ch(“mych”) but it not worked. Any way do it ?
try
@P.y>`ch(“mych”)`
as ch() is an expression
Don't know this for a fact, but you might need to use the global $TY, instead of @P.y depending on context.
G
keyframe
G
I think jerry was refering to syntax in group parm on sop nodes not actual pattern of Group SOP
whichever is the case, backticks apply to both of them for inserting a value using an expression
Thanks for replies!
Just as tamte said, i use them in Group parm on Sop node. It works!
Antoher question, how to use @P.y > @P.x in Sop Group parameter?
would love to know this one… It appears that in the group tab, you cannot do it and only using expressions such as $TY > `ch(“someParm”)` is possible
however, you can use them in the combine tab no problem..!
-G
