Hi there,
I'm playing around with primitive render hooks and having some trouble where my generated GR_Primitive gets deleted unexpectedly. I'm setting the GUI_HOOK_FLAG_COLLECT_PRIMS flag and deletion occurs whenever my GR collection primitive has a mix of primitives, some that do and some that don't meet the criteria (type) for the hook. I would expect the GR_Prim to be kept if it had at least on primitive that DID meet the criteria.
I'm looking at the docs re: this:
http://www.sidefx.com/docs/hdk13.0/hdk_viewport.html [sidefx.com]
Can you explain the 4th potential reason for deletion?
“If primitives were reordered in the detail such that a match between a primitive and its GR primitive could not be made.”
Thanks for your help!
Custom Viewport Rendering: GR_Primitive management
2554 5 2-
- omare
- 2 posts
- malexander
- 5262 posts
If you had a GU_Detail with the following primitives:
Primitive Sphere
PolySoup
Volume
and on the next cook, it changed to
PolySoup
Primitive Sphere
Volume
the GR prim for the primtiive sphere would be deleting as it no longer matches PolySoup. Houdini doesn't try to match forward in the list as that can led to very slow situations. It's also a relatively uncommon case.
Primitive Sphere
PolySoup
Volume
PolySoup
Primitive Sphere
Volume
- antc
- 354 posts
Once the GR_Primitive is deleted what is the expected draw behavior? We get a reliable segfault soon after the GR_Primitive is deleted and I'm wondering if that's a problem on our end or simply due to the absence of the primitive.
AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so>
AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler:
perator()(int, siginfo*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so>
_L_unlock_16 <libpthread.so.0>
RE_OGLBuffer::setLabel(RE_Render*, char const*) <libHoudiniUI.so>
restartCollection(UT_Thing&, UT_Hash const&, void*) <libHoudiniAPPS3.so>
UT_ThingList::traverse(int (*)(UT_Thing&, UT_Hash const&, void*), void*) const <libHoudiniUT.so>
UT_HashTable::traverseConst(int (*)(UT_Thing&, UT_Hash const&, void*), void*) const <libHoudiniUT.so>
GUI_GeoRender::update(RE_Render*, GR_DisplayOption*, GUI_SetupResult, GR_DecorationOverride, char const*, bool&) <libHoudiniAP
PS3.so>
GUI_DetailLook::updateForRender(RE_Render*, GUI_DisplayOption&, RE_LightList*, GR_DecorationOverride, char const*, bool&) <lib
HoudiniAPPS3.so>
DM_VPortAgent3D::setupGeometry(RE_Render*) <libHoudiniAPPS3.so>
DM_VPortAgent3D::renderViewport(RE_Render*, int, int, bool, bool) <libHoudiniAPPS3.so>
DM_VPortAgent3D::doRender(RE_Render*, int, int) <libHoudiniAPPS3.so>
DM_Viewport::doRender(RE_Render*, int, int) <libHoudiniAPPS3.so>
UI_Feel::renderMe(RE_Render*, int, int) <libHoudiniUI.so>
UI_Feel::doRenderKids(RE_Render*, int, int) <libHoudiniUI.so>
UI_Feel::doRender(RE_Render*, int, int) <libHoudiniUI.so>
UI_Viewport::reRender(RE_Render*, bool) <libHoudiniUI.so>
UI_Window::renderChildViews(RE_Render*) <libHoudiniUI.so>
UI_Window::doRedraw() <libHoudiniUI.so>
UI_Queue::doWindowRedraws() <libHoudiniUI.so>
UI_Timer::handleEvent(UI_Event*) <libHoudiniUI.so>
UI_Manager::handleEvent(UI_Event*) <libHoudiniUI.so>
UI_Queue::processNextEvent() <libHoudiniUI.so>
UI_Queue::drain() <libHoudiniUI.so>
UI_Queue::eventLoop() <libHoudiniUI.so>
main_part2(int, char const* const*) <libHoudiniUI.so>
main <libHoudiniUI.so>
__libc_start_main <libc.so.6>
_start <houdini-bin>
PS3.so>
HoudiniAPPS3.so>
- antc
- 354 posts
- malexander
- 5262 posts
- antc
- 354 posts
