How to get Max and Min from Ramp Parm(Sprine)
   3681   3   1
Just got some idea using Ramp Parm for altering start and end of particles forming and affect them Max and Min. I know that parm VEX has Key Position & Key Value, which are float array. Is it possible to use it for phasedly adjusting? Or any other options?
There is a Min and Max vop and vex command that should give you what you want.
Thank you Ratmann but I cloudn't get your idea…
Does it mean controlling float array data with vex script? It seems Min & Max VEX don't work with float array in Ramp Parm…
auratuslemma
Maybe you just need a fit vop with a start / end frame parameter values to create an attribute that's 1 or zero between a frame range.
Rob
Gone fishing
