Houdini 13 crash in RHEL/CENTOS 7
   7203   8   2
hi all
i just want to say that houdini 13 crash in RHEL/CENTOS 7
xorg also crash when i run houdini 13.
thanks a head , nir.
Hi Habernir! Please log a bug - thanks!
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=25347 [sidefx.com]
Chris McSpurren
I ran into this issue lately with the few latest nvidia beta drivers. When running H13, the whole X session would go down, right at the startup of H.
There already exists a bug for this.
You could check what driver you are using, and try to downgrade. The last beta driver I found working with H13 was 337.12
Everything after that mark would bring your X server down in an ugly fashion.
Martin Winkler
habernir
hi all
It's neither Houdini's bug nor CentOS. It's your card driver issue. I'm using same OS and same version of Houdini without any problem.
It might be driver issue, right now I can only use it with Nvidia 331 driver. What card are you using?
SreckoM
Quadro K5000
PradeepBarua
SreckoM
Quadro K5000
you right.
well thanks a lot everyone
i use quadro k4000 and k2000
and i try two version of drivers and it crash with both of them soo i thought it related to houdini BUT that was a driver issue .
Just a follow-up on this issue…
The newly (today) released stable nvidia-driver series 340.x looks safe so far.
Tested against 13.0.477 and X stays up, everything seems fine.
Martin Winkler
nvidia driver 340.32 is fine here on RHEL 6
Frederic Servant / Solid Angle / London
www.solidangle.com
