Post-Render Script - Delay a few minutes
   4437   2   1
Hi Guys,
I currently have flip fluid sim which is caching at about 5 minutes a frame.
I would like to leave another pc doing the whitewater sim overnight, but unless I put some sort of delay on the cache node it will
catch up with it.
What would be a Post-Render script so that in every frame the sim delays for a bit?
Or is there a better way of doing this?
Thanks,
Cris
You can write your delay script in the Windows –> Python Source Editor
Then call it in the “Pre-Frame Script” in the Mantra node parameters.
Mantra –> Scripts –> “Pre-Frame Script”
Just don't forget to set script type to Python . :wink:
Rabiee.Sadjad@Gmail.Com
I made a simple example file for you 8)
JKDelay_Render.hip (120.9 KB)
