Viewport Display Problems
   5287   13   0
When I load my geo I get a weird display in the viewport.
It sometimes goes away, but when I press “Alt” to navigate it shows up again for the duration.
It's driving me batty…. any ideas why this is?
Thank you
Attached how it should look vs how it looks when I press “alt” and open file first. :x
Winter is coming!
hi
please upload your project file with your 3d object until i investigate?
thanks.
Thank you for the help but there's nothing to upload.
It happens in any file I create. Even if I just lay down a cube in an empty file.
Or any file I open created by someone else.
Winter is coming!
Which OS, graphics card & driver? Have you tried the most recent graphics driver?
Mac Pro - 12 core - Bootcamped Win 7 - Latest AMD HD 5770 drivers with Catalyst
Worked just dandy for a long time - changed all of a sudden. Can't figure out why.
Would appreciate any troubleshooting advice.
I installed and reinstalled latest drivers.
Thank you
Winter is coming!
go to this:
edit—>preferences—>3D viewports
change scene renderer to GL 2.1 or 1.1
if with this way your problem fix, probably your driver have problem.
try different drivers for this problem.
NimaNolan
go to this:
Did that - tried Gl 1, 2 and 3.
Same issue.
Winter is coming!
now remove your driver and restart your pc and then open houdini with out installed driver.
try this way….
NimaNolan
try this way….
You mean uninstall the graphics driver?
If I do that and restart the computer it automatically installs it back. Besides, without it I cannot use the monitor resolution… and I doubt I could use Houdini either.
Or am I not understanding you correctly?
Winter is coming!
yes uninstall the graphics driver and then open houdini because with that way we can ensure about problem that it's from graphic driver or not.
NimaNolan
Did that - it appears that it IS from the graphics driver. I do have the latest. Maybe I should switch back.
Winter is coming!
NimaNolan
Installed my old driver - it works now… Thank you so much.
I did not install any new driver, but I do have Catalyst and I don't know if it updates drivers automatically or what.
Winter is coming!
sometime catalyst will get some problem with houdini just wait and don't worry for that and get every last version of catalyst until this problem solve.
thanks.
NimaNolan
thanks.
Will do - Thank you very much for all your help.
Winter is coming!
