Only Fracturing a Section of Geometry
   3412   7   1
Hello, I have a cylinder that I am wanting to fracture, however, I only want one area in the middle to be fractured while the top and bottom pieces are left unfractured. How can I accomplish this?
FixFracture_03.hipnc (3.9 MB)
You should have one point on Top and Bottom of the your cylinder , Because you wanna have only one piece on Top and Bottom :idea:
Check attached file :wink:
JKFracture.hipnc (133.8 KB)
Rabiee.Sadjad@Gmail.Com
Hey thanks for the reply,
When I add the voronoi fracture points node into my network, I see that wireframe but there are no points inside of the blue wireframe.
Maybe I'm missing something. Here's an updated file where I try to replicate what you had done.
VoronoiFracturePointsIssue.hipnc (3.9 MB)
Sorry , I can't download your file right now ,But it can solve usually with increasing Volume Resolution :?
Thanks a ton! Houdini is one tough program so it's nice to know there's a helpful community to help me improve!
If I could maybe bother you for one more question, How would I go about separating the geo so some of it is active and some is static? Even after grouping or deleting out certain parts, once I'm in object level it still wants to make everything active.
What about this project ? ,check it please :wink:
JKFracture.hipnc (293.0 KB)
Ah you're the best! Helped me learn a few tricks that'll definitely help in the future! You've helped me understand this confusing program quite a bit more here so thanks a bunch!
Your welcome my friend :wink:
