Hey guys, was wondering if support for bringing multiple objects under a group in maya is there (I know there is a way to use the fetch sop for bringing in transforms which is why I was wondering whether bringing in multiple meshes was supported yet)
thank you!
Support for bringing in multiple objects under a group
5385 8 2-
- grayOlorin
- 1807 posts
- awong
- 818 posts
- grayOlorin
- 1807 posts
Uhmm that is a good point I could keep the history. The thing is that I need the output of my digital asset to work on non combined pieces (ie I am layout uvs on multiple objects as a single entoty). I am going to see though if somehow I can leverage the history to bring back the output uvs to the original meshes somehow.
But yeah, the ability to be able to Marshall multiple meshes and consume them in houdini as groups in a single detail would be super duper
-G
- awong
- 818 posts
- grayOlorin
- 1807 posts
- grayOlorin
- 1807 posts
hey looks like I could also simply set a ton of inputs in my maya wrapper node
However, one thing I am wondering… is there a way to fetch the name of the mesh being inputted? if not, no biggie, I could always just re-fetch it later by name I presume
This may be a way to support multiple meshes in the short term I think if:
- we were passing the geo name as a detail attribute
- we had a means to pass an point index attribute back to maya to ensure the output meshes remained ordered as they were before (i.e. if a @pointnum explicit attribute exists, perhaps the engine can simply use it to order the points in a particular fashion on creation?)
-G
- awong
- 818 posts
grayOlorinAh, this is an interesting idea. Adding special detail attributes for inputs should be pretty easy.
I was actually thinking of doing something similar for controlling the output nodes when they are created by sync. So that certain attributes, like motionVectorColorSet, can be set when the mesh node is created by the sync process. We could also name output mesh nodes according to these special detail attributes. This won't be as simple as the input case though, and require quite a bit more work though.
grayOlorinSo the idea here is that you group each input, and then merge them together. Then, when outputting back into Maya, rely on Engine to split up the mesh into the original pieces by groups. I would have expected the face and vertex order to be maintained already.
Andrew / アンドリュー
- grayOlorin
- 1807 posts
yeah I think detail attributes could be a really nice way to pass information back and forth in between the engine and the host environment
I like the idea to be able to use detail attributes to drive things.
On that note, what are your thoughts on being able to have post cook/sync scripts that can be triggered in the host environment after a cook? (almost like a postCook python module in the digital asset). I could use this, for example, to trigger a DG node hook up in maya
Ill give that a shot. that would be phenomenal if it kept the indices!
I like the idea to be able to use detail attributes to drive things. On that note, what are your thoughts on being able to have post cook/sync scripts that can be triggered in the host environment after a cook? (almost like a postCook python module in the digital asset). I could use this, for example, to trigger a DG node hook up in maya
-G
- awong
- 818 posts
grayOlorin
Yeah, I had the same thing in mind too. Once a framework is in place for simple things like naming nodes and setting node attributes, it should be easy to extend it to support executing arbitrary scripts too.
Andrew / アンドリュー
