Error In Scene
   2875   3   0
I'm doing the following tutorial
https://www.sidefx.com/index.php?option=com_content&task=view&id=2262&Itemid=362 [sidefx.com]
but there are a few problems:
1) Errors upon loading the scene as “skipping unrecognized parameter”
2) The Houdini console never stops displaying “>>>”. I cannot close it. Even after I shut down Houdini it's still going…
Any thoughts? (using the H13.509)
Thank you!
Winter is coming!
try setting this environmental variable when launching Houdini:
export HOUDINI_DISABLE_FILE_LOAD_WARNINGS=1
MartybNz
Hi -
I've set this in the houdini.env file but it doesn't seem to have any effect. I still get the same thing.
It happened when I created the custom Desktop for lighting. I've since deleted it and recreated it, but I get the same error.
BTW - I've updated to 13.582
Winter is coming!
For anybody that faces this, the workaround is to open a python shell which then stops the empty lines and allows you to close the console.
The answer was from this thread:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=28091&sid=422f9237d971f97be3816dffdbc0a036 [sidefx.com]
Winter is coming!
