How to properly delete fur dynamics?
   2416   2   0
Hello.
What is the proper way of deleting fur dynamic simulation (created with “Add Dynamics” shelf tool)?
I deleted AutoDopNetwork node and some time later re-created it (also with the shelf tool), but fur won't simulate.
The Add Dynamics tool creates a DOP Network (if none exists) and inserts some nodes for the wire simulations. It also adds a couple nodes to the guide hair portion of the Fur Object to fetch the simulation results (a DOP Import SOP and “remove_simulation_attribs” nodes in the Fur Object's contained “guides” network). The only step you appear to be missing is cleaning up the nodes the shelf tool created to fetch the simulation results.
derrick
I found those nodes and deleting them seems to do the trick. Thank you very much, Derrick.
