Group display BUG
   5796   2   2
Hi guys,
Here is the situation:
I work in network view; create any object (grid, curve, etc.) and I add group sop. Viewport doesn't show grouped elements/geometry in color (yellow). Same example in old version works fine. It's not only me but few other people I checked with are having the same problem. Same example in old version works fine.
It's 7.0.231 build.
As I said, it works fine with 6.1.208 for example.
Is it some kinda bug?
Thanks.
It's a known bug.
To get round it you can manually turn on the highlight flag for the sop in list mode.
ok, thanks Simon. Found that help on odforce forum too.
And again Sesi: fix it !
