Fur: respect surface displacement
   2232   1   0
Hello.
I have a character that uses a displacement map and renders as subdivision surface. The character has fur applied to some of its faces. This fur was created with a shelf tool.
The problem I have, is that fur doesn't follow surface displacement, so on rendered images it looks like the fur grows from inside the skin.
How can I force the fur to respect the displacement map?
I understand that fur is created before subdivision and displacement are applied to the model. If so, is it possible to change this order?
I just noticed that fur shelf tool provides appropriate parameters that are needed for setting up fur displacement (in Appearance->Shape), and which I apparently missed. ops:
