I've found a partial solution to my previous question about selfintersecting polygons.
- Curvesect with itself - extract - affect left input - extract point
this adds the points of intersection to the existing points (leaving just points, no more primitives)
- Add - polygons - by group
This recreates the polygon
- Fuse - consolidate
To delete any duplicate points
- Tristrip
To generate individual triangles
- Point - Add normal
Now each point has either a normal facing in the direction of the prim normal, or facing away from the prim normal.
- Delete - By normal
If I could now delete by comparing the point normal with the primitive normal, I would be home free. :?
Jeroen
Self intersecting polys cleanup; a partial solution
3729 1 1-
- jeroenkrebbers
- 7 posts
- Simon
- 2199 posts
Sounds like you need to find the dot product between the point normal and the prim normal. That could get a little hairy unless you are happy with complex expressions. Not 100% sure it is doable don't have time to work it out right now… but knowing Houdini it probably is.
