Hi. I need to perform some actions in my Python Panel when houdini is exiting, and i can't catch this event.
1. closeEvent() is not called.
2. __del__() method is not called.
3. QApplication aboutToQuit signal is not emited.
Could you please tell me, how can i catch this event ?
from PySide.QtGui import *
import logging
class My(QFrame):
def __init__(self, logger):
super(My, self).__init__()
self.logger = logger
QApplication.instance().aboutToQuit.connect(self._app_quit)
def __del__(self):
self.logger.debug('In __del__')
def closeEvent(self, event):
self.logger.debug('In closeEvent')
self.close()
def _app_quit(self):
self.logger.debug('aboutToQuit signal')
def createInterface():
h = logging.FileHandler(filename=r'c:\temp\testhoudini_event.log')
logger = logging.getLogger('test')
logger.addHandler(h)
logger.setLevel(logging.DEBUG)
widget = My(logger)
return widget
Python Panel - how to catch application close event.
7817 4 2-
- Stalkerx777
- 183 posts
- edward
- 8081 posts
- Stalkerx777
- 183 posts
Hi Edward,
Yes, atexit works if registering a function from python shell or hou.session.
Doing so in python panel didn't work.
import logging
import atexit
class My(QFrame):
@atexit.register
def _exit(self):
self.logger.debug('In _exit')
widget = My(logger)
return widget
I'll try to install my custom event to QApplication, but this this a dirty hack…
import logging
import atexit
class My(QFrame):
@atexit.register
def _exit(self):
widget = My(logger)
return widget
Aleksei Rusev
Sr. Graphics Tools Engineer @ Nvidia
- rvinluan
- 1296 posts
- Stalkerx777
- 183 posts
rvinluan
Starting in tomorrow's build, the __del__ function will get called when the Python Panel is closed/destroyed.
We are still looking into hooking up __del__ so that it also gets called when the Houdini application exits/quits.
Rob
Hi Rob,
Currently, hideEvent is working like it should, why not make closeEvent working? __del__ should be good for now, but closeEvent should also work.
Anyway, thanks, at least we'll be able to save data
Aleksei Rusev
