Houdini Escape RenderPlus
8148 5 1-
- mookid20
- 36 posts
- edward
- 8081 posts
- mookid20
- 36 posts
- Simon
- 2199 posts
- rmagee
- 1341 posts
Renderplus is the Third party rendering support option for Escape. This lets Escape users access other renderers such as Renderman and Mental Ray in the same way Master already does. The Renderman VOP tools are also available in Escape with RenderPlus. The prices is mentioned in the article link posted above.
Rscript is a version of Hscript that provides a non-graphical interface for generating ifds or rib files.
- craig
- 557 posts
I might elaborate on that.
rscript is a cheaper, simpler version of hscript. The intention is that you use it to simply take a hip file and generate ifds/ribs. It doesn't allow you to do the hscripting tricks of changing object display flags, etc. It also doesn't allow geometry output, COP network output, etc. And you can't do the pre- and post- render scripts. But it does respond to the takeset command.
The way I think of it is: if you are using ‘takes’ to set up your render layers, then rscript will suit you fine. But if you are using the ‘standard’ Houdini technique of running hscript commands to create each output layer, then, clearly, you want hscript.
