Newbie question, but how do you move another object using a transform to the position of another objects transform (which has had its pivot redone with $CEX/Y/Z).
hello. i create switch node and after that add a transform node. so you can move to each connected object to switch node with one transform node that exist after switch node see project file for more info.
