bad topology rendering individual faces with differences?
   3274   2   0
I have some imported geometry with what I guess is considered bad topology (many stretched triangles, etc) and when it comes to rendering I get problems like this;
I've tried using a facet, and clean node and pressing different checkmarks to see the effect and haven't gotten anywhere. Using a remesh I get what looks like proper topology but it's dimenson and shape is obviously not the exactly same as the original - indeed is quite lumpy, and is also more polygon heavy. if I crank up the settings they seem more accurate but not enough to offset the time it takes or the end result (which is polygon city).
any help is appreciated!
Try setting the ‘Tangent Style to another setting. It’s in MantraSurface/Surface Model.
That seems to have done something good, cheers for that :!:
