hi
can someone load a simple tutorial how to export particles from houdini to maya?
i can't get it to work. not Alembic nor to Engine.
thanks
export particles to maya
19366 5 3-
- shai halfon
- 1 posts
- old_school
- 2540 posts
Was playing around with this the other day with some users as they were asking the same thing wrt Alembic as that would make a decent vehicle to transport particles, because it does support this.
Tests with Alembic using Maya2015(6) and Houdini14.0:
Works: export alembic particles from Houdini to Houdini
Works: export alembic particles from Maya to Houdini
Doesn't work: export alembic particles from Maya to Maya
Please perform the same tests. If you get the same results, log a bug with the Autodesk team.
If not, please let us know.
- awong
- 818 posts
Yeah, as Jeff said, Maya's Alembic support doesn't fully import particles. It can only import one static frame of particles/points. :?
You could use Houdini Engine to help importing the particles. The easiest way is probably to:
1. export bgeo files from Houdini
2. make an asset that contains only a file SOP
3. load the file sop asset into Maya, and use the asset to load the Houdini bgeo files
Andrew / アンドリュー
- old_school
- 2540 posts
- skoora
- 17 posts
In addition to:
Im trying to make nCache from created nParticle node. After attaching it to new nParticle node positions looks ok, even some custom renderman attributes, but I can't get particles size to work. When loaded through engine pscale works, but after caching connection seems to broken. In cache .xml there is a line
so I'm guessing, that its exported correctly, but do you know how can it be recognized again?
Im using maya 2015 and houdini 14 (quite old, I know, but that's what i have).
In addition to:
awong
<channel12 ChannelName=“output1_0Shape_radiusPP” ChannelType=“DoubleArray” ChannelInterpretation=“radiusPP” SamplingType=“Regular” SamplingRate=“240” StartTime=“36000” EndTime=“55200”/>so I'm guessing, that its exported correctly, but do you know how can it be recognized again?
Edited by skoora - Jan. 26, 2017 06:03:40
- skoora
- 17 posts
