I'd like to be able to use a ramp to control parameters in Vexpressions (mainly to control particles).
I've added a Spline Ramp to my node interface but I'm unsure of how to access it properly.
So in the screenshot/attached HIP I'm trying to get the force to push up/down/up.
Any help appreciated
Access Ramp Parameters in Vexpression (POP's)
3751 2 0-
- Simon Russell
- 166 posts
- Simon Russell
- 166 posts
- animatrix_
- 5247 posts
Simon Russell
Someone from the Twitter helped me out:
float updown = fit01(chramp(“grad”,@nage,0), -5,5);
force = set(0, updown, 0);
or
float ramp = fit01(chramp(“grad”,@nage,0),-5,5);
force.y += ramp;
For some reason I thought you declared a float with f@xxx, no idea why…
IMO it's not a good practice to do that. It's better to use local variables and in the end only export/set the ones you want to export/set as an attribute with the @ syntax. Otherwise you will end up with a lot of unnecessary attributes.
One exception is if you want to declare and set the value in the same line, then using @ is acceptable IMO.
