Hello, I got some issues displaying geometry in shaded mode in the viewport in H14. In wireframe mode I can see the geometry as expected. But as soon as I press “w” to switch into shaded mode the geometry disappears entirely.
Via the environment variable HOUDINI_OGL_DUMP_SHADER_ERRORS I got the following error message:
Geometry shader compile:
0:5(12): warning: extension `GL_EXT_gpu_shader4' unsupported in geometry shader
LINK:
FS compile failed: bad cond code
Mesa 10.1.3 implementation error: Failed to compile fragment shader: FS compile failed: bad cond code
My system:
Linux Mint 17.2
No dedicated graphics card
CPU: i7-4790K with Intel HD4600 graphics
MESA driver: 10.1.3 (current version for Linux Mint 17.2)
Btw, I had similar problems with H14 under Windows 7 with the latest graphics drivers from Intel.
Any solution for this?
Problem displaying geometry in shaded mode (Intel HD4600)
4573 7 0-
- yogoo
- 3 posts
- Enivob
- 2658 posts
- yogoo
- 3 posts
- malexander
- 5265 posts
- malexander
- 5265 posts
- Konstantin Magnus
- 718 posts
I am new to Linux and just installed Houdini 15.0.244.16 (production build) on Mint. Running into the same problems No geometry visible in shaded mode.
So far I downloaded mesa-11.0.5.tar.xz from ftp//ftp.freedesktop.org/pub/mesa/ and extracted it. Is this the correct one?
If so, how can I update a MESA driver?
____________________________________________
3.16.0-38-generic #52~14.04.1-Ubuntu SMP Fri May 8 094357 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Intel Core i7-4790T with HD4600
yogoo
Meanwhile I found a solution. I updated the MESA driver to version 10.3.0 directly from 01.org. Now it works fine for me.
Maybe there is a bug in the current MESA version 10.1.3 delivered with Linux Mint 17.2.
- Konstantin Magnus
- 718 posts
solved it for me with
http//www.apolitech.com/2015/09/how-to-install-intel-and-amd-oibaff.html
