Hi, Maybe a simple question. I simulate particles in DOP network in SOP node. I created attribute before DOP node to get it's value in DOP and use as a simulated value ( like in xsi simulated tree ). So the previous frame value will be the new value of the current frame. Are the bound attributes in vop pop in a DOP nw behave like that? I know the node Solver node in SOP. Is there a similar in DOP nw? Thanks, G
If I understand your question, yes there is a SOP Solver in DOP's, it's also called a SOP Solver. Actually, the one in SOPs is just an OTL, with this one embedded inside of a dop network!
