The viewport in Houdini often looks great, so great in fact that I would like to render it.
Is there a proper workflow for rendering out OpenGL frames from the viewport or is it just a case of doing a flipbook with good quality settings? Is there any way of getting an alpha with the flipbook?
The viewport looks great!
3497 4 1-
- Sam Howell
- 87 posts
- Doudini
- 333 posts
- Sam Howell
- 87 posts
- Enivob
- 2658 posts
There are some limitations, however. The OpenGL ROP is not an exact copy of the view port. For instance Volumes are not lit which is a big let down. Also any viewport effect that is being driven from a GLSL shader is not rendered either.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- Sam Howell
- 87 posts
Just turn on Ambient Occlusion or whatever you need in the Display Option of the opengl rop.
