Rest position in pointvop
   3646   2   2
I'm applying turbnoise to deforming points in a pointvop, even though I've set the rest position upstream I'm still getting swimming. Is this something I need to explicitly sets in the pointvop? Thanks!
The rest position are stored in a separate attribute “rest”, and not “P”. Did you try using that to generate the noise? You can access the “rest” attribute with a bind VOP. The noise should be generated from the rest position, but applied to the deformed geometry using “P” (and probably “N”). See the attached hip file.
rest_point_vop.hip (73.0 KB)
Andrew / アンドリュー
Thanks for the response, it turned out to be an issue with the scatter sop randomly changing point order, I was able to fix it generating points in texture space instead of by density
