I have a curve with a few points, (group1)
I resample the curve using the resample by polygon edge setting and a fixed distance between points, (group2)
I would now like to delete those points which were in the original curve.
Since each line section of the curve may be a different length, there doesn't seem to be an expression I can use to group and delete these points.
Please someone tell me how can I delete the points from group2 which are also in group1? I can't figure how to do this with the delete, group or blast nodes but I feel I'm overlooking something simple..
thanks all!
how to remove points from a group based on another?
7529 4 2-
- nikalaris
- 10 posts
- mestela
- 1854 posts
normally you'd use the group logic on the combine tab to say ‘group2 != group1’.
As you've found though, the resample blows away your groups, so that's no good.
Here's an alternative method. create an attribute with a pointwrangle, ‘@deleteme=1’. Run the resample, another wrangle, ‘@deleteme=0’.
Add an attribtransfer, and transfer the pre-resample deleteme with a short falloff to the post-resample.
You can then blast based on @deleteme==1.
- tamte
- 9407 posts
- mestela
- 1854 posts
- nikalaris
- 10 posts
