Very happy
   3805   5   0
about two features/improvements as they're two thjings I've submitted RFEs for:
1- Child compensation (make it available under “keep…”)
2- Match Transformations
Now, problem is I can't find the 2nd anywhere. Help didn't help.
Holy crap, that's cool!
You know what's missing? A “match all” button above the existing ones. Or even better, shift LMB on any of them to match all and ctrl on the one you want excluded
You should log an RFE for that if you haven't already.
Chris McSpurren
If you're feeling adventurous (and/or bored), you can also try modifying $HH/python2.7libs/objecttoolutils.py, the matchTransform function in there is what gets run when you hit those buttons. You can look at the kwargs argument to determine if the ctrl or shift keys are being pressed, and behave differently if they are.
Thanks Mark for the suggestion, but no thanks
I don't do Python, didn't write a line of code since 10 yrs ago (which was c not python) and besides, I have a model to finish (in XSI duh) which I'll use it for hopefully becoming proficient in Houdini's shading and Mantra rendering.
Submitted a RFE
