Soft Radius and Edge rotating issue
   1962   0   0
Two little problems…initially the colour display for the soft radius didn't work, after I changed the desktop setup(technical->modelling->technical) it seems to be working now but is there a setting to turn it on and off. And, with the edge selection is twisting 90deg when I drag it, this only happens on the first move after that , it does not matter which handle(Rx, Gy, Bz) I pick it moves fine
