2D plane and alpha channel
   2558   2   0
Hi I'm a long time sketchup user new to Houdini.
In Sketchup with Thea render I was experimenting with making grass from 2d planes containing an image, with the alpha channel transparent and the visible image translucent. (see image below)
Is this possible in Houdini apprentice Mantra and if so is there a tutorial showing me how to do it.
Grass new-Scene 2.jpg (459.8 KB)
Just add a principled shader to your plane (called a grid in houdini).
Activate the texture map for the diffuse surface and place your diffuse texture there. Do the same thing for opacity only use the alpha version of the texture for that slot.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
I'm a total newb so don't know what your talking about, but having someone confirm it can be done is good. and when I know what your talking about I'll try it. Thanks
