Hi to All,
I'm having trouble whit the new polyextrude node.
With the old one I could simply get a result like this (see attachment) using the following technics:
1) create one (or more) normalized prims attribute.
2) manage the attribute value with spline ramp.
3) use the resulting value in a polyextrude node as scale or inset multiplier.
Whit the new one this technics doesn't work anymore.
I have found this topic https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=41944 [sidefx.com] that talk about this, but the reported solution doesn't work in my case: the “localzscale” attribute works only with “individual element” extrusion mode, and that is not what i want.
Is theres a way to get the same result with the new poly extrude node?
It would be possible to get back the old poly extrude alongside the new one (this is for Sesi)?
Thanks in advance
