visualizer showing duplicates
4789
6
1
phtj
Feb. 7, 2016 5:56 a.m.
When I visualize an attribute with a numeric value (Style = Text), it seems to be showing the same number two times. See attached image. Am I doing something wrong?
Patrick
jerry7
Feb. 7, 2016 6:13 a.m.
I have same problem when use Visualize sop node. And adding marker in viewport option is no problem. Maybe a bug?
zdimaria
July 11, 2018 5:41 p.m.
I am also getting this issue 16.5.410, did you ever find a solution?
Sept. 7, 2018 12:33 a.m.
Try to bypass the Visualize SOP (but still active the visualizer in the viewport).
Andr
Feb. 21, 2019 5:56 p.m.
3 years later.. It's still happening in Hou17. I wonder if that's a bug, or some hidden toggle we missed?
Edited by Andr - Feb. 21, 2019 17:58:16
Andr
Feb. 22, 2019 3:08 a.m.
I asked the support, the bug is logged as BUG #92140 If you need it to be fixed, you could send an email to the support team, referencing the id. Cheers
Andr
Feb. 25, 2019 1 p.m.
update, I found a simple solution to get rid of the annoying duplicate text: just append any node (I use null) to the visualizer and set the flag on it.
Don't know why, but it works
Edited by Andr - Feb. 25, 2019 13:00:55
