select one random polygon per frame
   2266   3   1
I'm trying to extrude one randomly selected polygon per frame, on a grid. I'm using the group node and the expression mode to select, but i just can't seem to get it working. Any suggestions?
$FF in group pattern?
random_poly.hipnc (57.6 KB)
Or lazy way, sort sop in random mode (with the seed as @Frame), then make your extrude group be 0, ie, the first prim it finds, which will change every frame.
rand_extrude_sort.hipnc (52.8 KB)
oh yeah the sort way does it perfect, thanks.
