how to get the "label" of an item in ordered menu
   16774   2   2
I have an ordered menu with each of its “Token” associated with a string “Label”. (image 08 )
May I ask how can I use either Hscript or Python to get the Label string once I select an item from the menu?
I tried the following but it always return the numerical index or the token value of the menu item selected … (image 09 & 10)
Thank you very much!
something like this:
parm = hou.pwd().parm("case_name_list")
value = str(parm.eval())  # convert to string since you have ordered menu
if value in parm.menuItems():
    index = parm.menuItems().index(value)
    return parm.menuLabels()[index]
else:
    return "value %s not found in menu" % value
EDIT: updated formatting as it was lost over time
Edited by tamte - July 11, 2018 12:44:58
let's take above example where i have same menu and here i want to list my directory in that menu with same labels & token how we can do that?
FX TD
Double Negative
