Question about POP advect node
   2400   1   0
I'm studying POP network using tutorial.
The tutorial is little bit old so it used old-pop.
But I want to make same result in new-pop(?).
Here I attached hip file.
I think POP advect node is a problem, however I coudn't figure it out.
If I use a old pop, It works. What's the problem?
Thank you.
ex_volume2.hipnc (287.6 KB)
I found a answer.
I didn't make volume name.
