If I use vertex UVs on export to other programs it turns out that every triangle in the UVs is separated. Most other applications do not a appreciate that. I can clean that up in Maya, but that is not a good workflow.
If I promote the UVs to a point attribute they borders of the UV islands get fused (which is not what I want for obvious reasons).
If I promote the UVs to a point attribute using a vertex split sop, the UV islands stay separate but the geometry gets split apart (and the normals get messed up in the process).
Is there a way to achieve a proper UV export without messing up the geometry?
- I suppose I could transfer the normals from before the split onto the split version, but in a package like Maya such a mesh would have to be considered broken. To further process such a mesh in Maya I would have to unlock the normals (and lose all normal information I defined in Houdini) and merge (fuse) the mesh. Undoing all the work I have done in Houdini.
UV to point promotion issue
7148 10 1-
- DASD
- 490 posts
- DASD
- 490 posts
- Benjamin Lemoine
- 149 posts
- DASD
- 490 posts
- Benjamin Lemoine
- 149 posts
Hello ,
Thank you for your answer
I know the first technic (i used to do it with Max)
but i would prefer not to have to open another software
so i will try your script .
(sorry , i just realized you were mentioning script within maya
toobad for me …
it would be great if maybe one day Sidefx add the possibility to do it at export !)
at least for unity or unreal because it's not good for the engine to have too many seams…
toobad for me …
Edited by Benjamin Lemoine - Nov. 13, 2016 05:49:35
- DASD
- 490 posts
It should work the same way in 3Ds Max. I don't have it handy right now, so I cannot check.
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMax/files/GUID-9E98AEAC-F06F-4FAD-9091-DCD30AC9BB26-htm.html [knowledge.autodesk.com]
Should be welding with a (small) treshhold.
- Benjamin Lemoine
- 149 posts
- arjanM
- 28 posts
- DASD
- 490 posts
arjanM
Hi, I have the same issue with using the Houdini engine in Unity.
I can't bake shadows on the mesh that gets generated by the houdini asset in Unity.
Does anybody know a way to fix this in houdini?
Try checking the Unity Houdini Engine subforum and maybe make a thread there. Or is it solved already? - If your research comes up with nothing make an RFE.
- dpernuit
- 560 posts
- DASD
- 490 posts
