Hello guys,
I have a problem in Mantra, when i render single frames, there is nothing wrong but whenever i tried to batch renders on the disk, it stops right after the first frame.
It does render it with correct frame padding $F, but never goes to the 2nd frame …
“Clear completed works” is checked in scheduler…
The mantra is underlined in red and says : error saving geometry for import_pyrofields
I don't know if you have any clues how to fix that !
Thanks anyways,
EDIT : Problem solved, simply a cache problem !
Tim
Rendering frame range problem
3613 0 0-
- Timothe Bevilacqua
- 1 posts
