Scene Scale How to?
   14480   7   3
Hi folks, my pipeline is Maya > Houdini> Maya
I am a bit confused about scene scale.
Please help me! Thanks in advance.
These question are bogging me down::
1. How much percent should I scale my objects in Maya to simulate properly in Houdini space?
2. If a real building is lets assume 260 meter high then what should be uniform size of it in maya and in houdini?
3. If I want to make some ocean sim what should be the size of the ship and the tank?
4. How can I understand this facts? Please give me some book/reference/tut if you can.
Thanks for your reply!
http://www.digitaltutors.com/tutorial/1916-Using-Houdini-Engine-to-Simulate-Finite-Elements-in-Maya [digitaltutors.com]
http://www.digitaltutors.com/tutorial/2130-Modeling-for-Dynamics-in-Houdini-and-Maya [digitaltutors.com]
this path can talk around this, Houdini has default settings 1meter-1kg for dynamics if i remember. You can use houdini tool plugin for maya for switch & test scales.
3dfan
przems
Thanks a ton for the suggestion!
wow
3dfan
Houdini > 1 unit = 1 meter
Maya > 1 unit = 1 centimeter
if your object in Maya is 180 units tall in Y (6 foot man)
then to send this model to Houdini you can do one of the following:
in Maya - scale the object UP by 100, then export
or
in Houdini - import the object and scale DOWN by 100 (x 0.01)
this will result in an object that is 1.8 units tall in Y - (1.8 meters)
then to go back to Maya do the reverse
in Houdini - scale the object UP by 100
or
in Maya - import the object and scale DOWN by 100
hth
Edited by - April 15, 2016 11:35:00
Training Lead
www.sidefx.com
arctor
Houdini > 1 unity = 1 meter
or
or
hth
Thanks for such a simple explanation..
Also keep in mind to avoid scaling cameras ( especially when rendering volumes ), as this can give you very unexpected / wrong results.
indeed!
NEVER scale cameras (or lights for that matter)
Training Lead
www.sidefx.com
