I've just installed Houdini with an Apprentice license. Are there any specific SOPs or other things not part of Apprentice?
I ask because I'm not able to find ‘voronoi fracture points’ or any voronoi SOPs via the tab menu other than ‘voronoi split.’ I have found ‘voronoi fracture’ via the left hand shelf. But it does not appear in the tab menu.
I also notice I have several DOPs in the shelf that are represented by an H icon and are labeled ‘undefined.’
Finally, when I select simple primitives (such as spheres) in the viewport or the network, the properties area is blank. I cannot see the translate, rotate or scale, for instance.
Are any of these Apprentice limitations, or has something gone wrong with my install?
W
Absolute New guy with a few simple questions
3888 6 0-
- kokosing
- 8 posts
- circusmonkey
- 2624 posts
- kokosing
- 8 posts
- kokosing
- 8 posts
- SreckoM
- 381 posts
- kokosing
- 8 posts
Thanks. I've launched from the terminal and got the same result. I did spot two errors in the terminal about not being able to create temporary files in my user directory.
I've also uninstalled and reinstalled with the same errors.
I really hope I can sort this. The tutorials have got me well worked up.
W
W
- kokosing
- 8 posts
