Setting Asynchronous mode programmatically before running maya
   3773   2   1
Is there a way to query or turn the Asynchronous flag off programmatically before starting a maya process? I.e via setting an environment variable in python or C#?
I know in Maya, when we turn that optionVar off, it requires a restart, which made me think this would be possible?
Thank you!
-G
One way is to use the userSetup.mel. For example, you can add:
if(size(`getenv FOO`))
optionVar -iv houdiniEngineAsynchronousMode ((int)`getenv FOO`);
The same can be done using Python with userSetup.py.
Andrew / アンドリュー
Thank you Andrew! That works!
-G
