New Houdini Indie v 15.5 Mac OS X 10.11 freezes on save as .hip
5741 12 1-
- PaulTurcott
- 9 posts
I just purchased a copy of Houdini Indie and I'm going through the Houdini essentials training series on Lynda.com. So when I went to save the scene as a .hip file, the interface pops up to allow you to name your scene but when I click on it to use it, it's completely unresponsive, frozen. I go to click on cancel and nothing, the whole interface is stuck, every time and in ever version of Houdini. I have to go over to my other screen and open force quite to get out of it. I'm thinking this may be an El Captain issue. But I'm not sure. Has any one using Houdini on a Mac with OS X 10.11 experienced this?
Paul
- Enivob
- 2658 posts
- PaulTurcott
- 9 posts
Sure, here they are:
Model Name: iMac
Model Identifier: iMac15,1
Processor Name: Intel Core i5
Processor Speed: 3.3 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Memory: 8 GB
Boot ROM Version: IM151.0207.B06
SMC Version (system): 2.22f16
AMD Radeon R9 M290:
Chipset Model: AMD Radeon R9 M290
Type: GPU
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 2048 MB
Vendor: ATI (0x1002)
Device ID: 0x6819
Revision ID: 0x0000
ROM Revision: 113-C408A0-729
EFI Driver Version: 01.00.729
Displays:
iMac:
Display Type: Retina LCD
Resolution: 5120 x 2880 Retina
Retina: Yes
Pixel Depth: 30-Bit Color (ARGB2101010)
Main Display: Yes
Mirror: Off
Online: Yes
Built-In: Yes
Model Name: iMac
L3 Cache: 6 MB
Memory: 8 GB
AMD Radeon R9 M290:
Type: GPU
Bus: PCIe
Device ID: 0x6819
Revision ID: 0x0000
Displays:
iMac:
Retina: Yes
Main Display: Yes
Mirror: Off
Online: Yes
Built-In: Yes
Paul
- PaulTurcott
- 9 posts
- Enivob
- 2658 posts
I am using Houdini 15.5 on my MacMINI running El Capitan so I don't think it is OSX related. Your machine seems to be up to spec for video card. The only other thing you might want to try is to run Disk Utility and check your disk for problems. A lockup on save might still be related to a bad sector on the disk.
Can you do a save on the default empty scene?
Maybe try saving to a USB drive just as a test..?
Do you have any strange non-english characters in your system user name?
Edited by Enivob - June 11, 2016 08:57:23
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- anon_user_37409885
- 4189 posts
PaulTurcott
Try in the preferences set the ‘File Choosers’ to ‘Native Chooser Only’, under General User Interface
- PaulTurcott
- 9 posts
Hey thanks for responding Artye and Enivob. So, I did switch to the setting ‘Native Choosers Only’ in the preference settings under general and it's still misbehaving. I just maxed out my memory today to 32GB and cleared 400GB of old crap off my machine.
I also started from the Houdini terminal script and I get this error code:
Last login: Sat Jun 11 15:48:15 on ttys000
Pauls-iMac:~ paulturcott$ /Applications/Houdini\ 15.5.502/Houdini\ Indie.app/Contents/MacOS/hindie ; exit;
libpng error: Not a PNG file
I'm wondering if it could be something in the info.plist file.
Paul
- 4189 posts
- PaulTurcott
- 9 posts
- 4189 posts
That's sounds like you're at the root level - the library folder for Houdini is from the home directory, i.e. ‘~’
Try holding down the option key and in the Finder use the Go menu, the library folder will appear in the menu with the option key pressed, it's hidden by Apple - then navigate to /Preferences/houdini/15.5.
- rvinluan
- 1296 posts
- PaulTurcott
- 9 posts
Thank you rvinluan. No I don't have an HQ network mounted for a farm or anything like that though I'm working on getting there. However, when I downloaded v15.5.503, it was highlighted in yellow so it's been having some problems. So still not sure what's causing it, it's really quite mysterious.
Paul
- PaulTurcott
- 9 posts
