iMac 5k, anyway to make the app run in the appropriate resolution?
   3595   6   0
Just installed Houdini on my iMac 5k and was a bit annoyed to see that the app doesn't support retina out of box. Is there a known workaround for this?
It's not very usable in it's current state.
Try two things:
set the env var HOUDINI_ENABLE_RETINA = 1
In Houdini preferences set Global UI Size to HiGH DPI.
Edit > Preferences > General User Interface > Global UI Size (at the bottom) > choose High DPI
Training Lead
www.sidefx.com
Backing scale factor is a useful way to runtime detect this information:
https://developer.apple.com/library/mac/documentation/Cocoa/Reference/ApplicationKit/Classes/NSWindow_Class/#//apple_ref/occ/instp/NSWindow/backingScaleFactor [developer.apple.com]
self.window.backingScaleFactor == 2 means retina.
Edited by SirRage - June 14, 2016 15:29:39
If you want to post bugs and feature enhancements than use the Support menu above ‘Report a Bug/Rfe’. That logs a ticket with the support, which is excellent.
BTW you'll find that simple searches of Apple docs is theme of some newbies to Houdini, to which the Devs here a fully capable of doing too.
Alright, I filed a bug.
Artye
…BTW you'll find that simple searches of Apple docs is theme of some newbies to Houdini, to which the Devs here a fully capable of doing too.
Well, if you say so. There are many other ways to accomplishing this task, but after looking at a few different ways of doing it this looked to be the preferred way. I don't feel bad sharing some of that knowledge given I've been doing MacOS develop for some time now.
Great! - you'll find the devs more than willing to take good advice that fits with the program. Welcome aboard!
