Anyone knows how to export object id from Houdini to after effects.
I try using the extra image plane with Op_Id on an exr file but nothing…not so sure if it is a houdini or After effects problem.
objects id for after effects?
4480 3 1-
- Nicolas Heluani
- 303 posts
- Enivob
- 2658 posts
The general consensus is that After Effect open EXR is broken. As of CC 2015 Adobe has not updated any of the 3D Channel tools to work with modern file formats. Another case of legacy rot within the After Effects effects system.
So people say use Nuke instead of After Effects.
You can view that the Op_Id is being exported correctly by simply bringing in one of your outputted EXR file into the Houdini COPs system. There you can use a luma key node to isolate the Op_Id for the object. In order to find the actual Op_Id of any object CTRL-Click on it in the render view when it has no material assigned (what a drag, CTRL-Click pops up a Mantra dialog instead Pixel Information if an actual material is assigned.)
So the work around would be to render out your EXR files with Op_Id, bring them back into Houdini and key out the object IDs using the lumakey node. Follow that up with a ROP Output Driver to write the keyed object back out in an After Effects friendly format such as PNG or JPG. Then you can use them as animated mattes over the master render sequence.
Edited by Enivob - June 26, 2016 12:05:55
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- Nicolas Heluani
- 303 posts
- Enivob
- 2658 posts
