Get Object Transform in VOPs of Object
   2690   2   1
Hi all,
I'm coming from Lightwave and, as you can see in the attached image, when shading I can have a node that refers to the current item (Item: Self) and get supplied various bits of information about that item.
So, how would one do this in VOPs?
http://www.sidefx.com/h15-masterclass-material-stylesheets/ [sidefx.com]
Something like this?
I don't know if you mean with “object” a complete model, a group/part of the model,
polygons(primitives), points, …
nearly everything can drive a shader
maybe you are looking for something like the attached…
use “technical desktop” then it's easier to understand, what*s going on.
You cann attach arbitary attributes to points, primitives, …
and then use them in other context
Edited by matthias_k - July 8, 2016 17:32:30
attributes_in_shader-1.hip (204.7 KB)
Coolio - thanks matthias! This should help, but I was just wondering about the efficiency of storing this into per point, but I suppose you can do the same thing with a detail attribute too?
