Compare two arrays in a wrangle SOP if statement
   6424   3   1
How do I compare two arrays in a if? Do I need to iterate the comparison in a foreach or is there an easier way?
float maxdist = 0.5;
int maxpoints = 15;
int current[] = pcfind(0, "P", @P, maxdist, maxpoints);
int orig[] = pcfind(1, "P", @P, maxdist, maxpoints);
// Well, this doesn't work...
// i@group_broken = (current[] != orig[]) ? 1: 0;
int maxpoints = 15;
// ...or this...
// i[]@current = current;
// i[]@orig = orig;
// i@group_broken = (i[]@current != i[]@orig) ? 1: 0;
Edited by Farmfield - July 11, 2016 10:33:01
~ Messing about with pixels, vectors and voxels since 25 years [vimeo.com] ~
not 100% sure , but I assume if you need to test the arrays are identical to each other you would need to loop over and compare each element
you can break the loop as soon as one of the values fails the comparison test something like this:
int tester = 1;
int count = 0;
if( len(array1) == len(array2)
while( tester )
if( count = len(array1 ) )
tester = 0;
if( array1 == array2 )
count += 1;
else
tester = 0;
Wow, I thought I had it set so I get a mail when someone replies - apparently not. Much appreciated, I'll check it out, see if it works for the setup I was messing with.
I have noticed the same thing with not receiving notifications
I just ran a quick test of my previous slap code and noticed a few errors, here is a working example run in a detail wrangle:
i[]@ar1 = {0,1,2,3,4};
i[]@ar2 = {0,1,2,3,5};
int tester = 1;
i@result = 0;
int count = 0;
if( len(@ar1) == len(@ar2))
while(tester)
if( count == len(@ar1) )
tester = 0;
if( @ar1[count] == @ar2[count] )
count += 1;
@result = 1;
}else{
tester = 0;
@result = 0;
}else{
tester = 0;
the detail attr result will return 0 if the array is different and return 1 if they are equal
it looks like my code got munged a bit…all the brackets got removed…fixed it now
Edited by sidenimjay - July 14, 2016 11:28:57
