hello, I'm trying create geometry from a group of point,polar coordinates, from an array.
It gives a meshed sphere but with hole, and overlapping points.
I guess I shd use some condition but I'm not really sure how..
int total =40;
int prim;
float r = 200.0;
float lon = 2*($PI); //-pi,pi
float lat = 2*($PI);//-pi/2, pi/2
float step_lon = lon/total; //angle sur la longitude
float step_lat = lat/total;//angle sur la latitude
int globe = {0,0,0};
vector pos ={0,0,0};
for (int i=0 ; i<total+1; i++){
for (int j=0; j< total+2; j++){
//polar to cartesian
float x = r * sin(lon) * cos(lat);
float y = r * sin(lon) * sin(lat);
float z = r * cos(lon);
//vector pos
pos = set(x,y,z);
//feed array, create points sphere
globe=addpoint(geoself(), pos);
int v1 = globe;
int v2 = globe;
int v3 = globe;
prim = addprim(geoself(), “poly”);
addvertex(geoself(), prim, v1);
addvertex(geoself(), prim, v2);
addvertex(geoself(), prim, v3);
//setpointattrib(geoself(), “lat”, v1, j, “set”);
// setpointattrib(geoself(), “lat”, v2, j+1, “set”);
//setpointattrib(geoself(), “lat”, v3, j+2, “set”);
lat += step_lat;
lon +=step_lon;
u will find in my hip file, vex code for creating a sphere, then a mesh.
thks
Create a Sphere Geometry in VEX
6243 3 1-
- ezza
- 2 posts
- Enivob
- 2658 posts
I think you need to calculate one more point. You see holes because you have 3 points forming a triangle inside of a quad area.
Here is a link [gamedev.stackexchange.com] to a possible solution for calculating the fourth point but you may want to search a bit on your own.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- ezza
- 2 posts
- mestela
- 1853 posts
Sorry for the late reply, but I was wondering a similar thing, found your wrangle, tidied it a little to make it properly mesh. You might find it useful…
(double edit)
Heh, as soon as I posted it I can see it can create some bad geo if you set the sliders incorrectly. ‘Lon Mult’ should be 2, ‘Lat Mult’ should be 4.
-matt
(double edit)
-matt
Edited by mestela - Feb. 1, 2017 05:26:06
