Problem using Renderman RIS and ptex textures in Houdini
   5347   6   1
Hello everyone
I have encountered a few problems when transferring ptex textures from Mudbox into Houdini. I am using Renderman in Houdini, but loading ptex textures through a pxrptexture node into the diffuse channel of a BxDF yields weird results. The textures seems to be tiled so my guess is that something is wrong with the face id's.
I simply exported the geometry from mudbox as an obj. file along with the ptex texture created in mudbox and used a file-node in Houdini to import it. I applied a pxrDisney material with the pxrptexture hooked into the base color slot. Any ideas on how to set it up correctly or what I am missing would be greatly appreciated.
cheers
Is it possible to share the file with the problem?
Maybe this could help. It should work in indie with renderman installed. I applied a test ptexture to a generic mudbox sphere. The jpeg image is how it should look. It definitely seems as though the ptexture is getting tiled pr polygon so I am almost certain that missing face indices are to blame for the problem. But I have not found a way to apply them in Houdini.
HP.hiplc (193.8 KB)
ball.obj (40.1 KB)
ballpaint_sphere.ptx (3.4 MB)
Here is the result in Houdini btw …
First you need to create a __faceindex attribute.
Then maybe you have to flip the ptex.
My demo ptex comes from 3D Coat :-) , which has a “Flip” option in the ptex export menu.
Compare test-c and test-d render.
If you test my scene, please set back the “Command” to your needs
Hope that's helpy
Edited by matthias_k - Aug. 9, 2016 19:04:12
HP-1.hiplc (227.5 KB)
test-c.ptx (166.5 KB)
test-d.ptx (166.0 KB)
had a look in mudbox, no flip option :-(
Maybe try a reverse sop, see image…
or use 3D Coat ;-)
http://3dcoat.com/home/ [3dcoat.com]
Thanks so much matthias_k It works perfectly ! It was the attribute rename sop I was missing. And you do have to use a reverse sop at the end to flip the ptex. Awesome
