Modeling with background image
   12101   5   2
Hey guys,
I'm trying to model over a background reference image with semi-transparent (ghosted, x-ray) geometry, think 3DSMax alt+x.
I've searched the forums, docs.. came up empty. Sounds soo simple right?
Any help would be appreciated.
Press the D-KEY while your mouse is in the 3D viewport and click on the Background TAB. You can specify a background image for the perspective camera viewport.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
I like modeling with a reference image displayed on a Grid as a texture as an alternative to setting the background. If you want you can move the Grid containing the image around and position it how you want! Rotate the Grid 90 degrees to make it a background.
The beginning of this displacement example video will show you how to do it with with just 3 nodes! Of course for the reference image you do not need to bother with displacement.
http://www.sidefx.com/tutorials/opengl-displacement/ [sidefx.com]
Edited by CreateTheImaginable - Aug. 12, 2016 01:32:26
@Enivob, I have all that setup, it's the geometry transparency I cant figure out.
@Imaginable, Thanks… I just watched the video and that might do the trick.
I also cannot figure it out quite well
I try to create Alpha attribute to change the poly's Alpha..
Go to the display options, and in the Markers tab, turn on “Ghosted” (last column).
