Hi everybody,
I just installed houdini 15.5.570 and every display mode (flat shaded, smooth shaded, …) is in wireframe in the viewport.
Does anybody know if it's a bug or if it's coming from my graphic card?
Viewport only display geometry in wireframe mode
3849 2 0-
- robP
- 8 posts
- goldfarb
- 3465 posts
- robP
- 8 posts
Houdini Version 15.5.570
Platform: windows-x86_64-cl19
Operating System: Windows 7 Ultimate x64
Number of Cores: 4
Physical Memory: 7.84 GB
Number of Screens: 2
Screen 0: 1920 x 1080 at 0,0
Work Area 0: 1920 x 1040 at 0,40
Screen 1: 1440 x 900 at 1920,180Houdini Version 15.5.570
Number of Cores: 4
Work Area 1: 1440 x 900 at 1920,180
OpenGL Vendor: Intel
OpenGL Renderer: Intel(R) HD Graphics 4600
OpenGL Version: 4.3.0 - Build 10.18.10.3650
OpenGL Shading Language: 4.30 - Build 10.18.10.3650
Detected: Intel HD Graphics Consumer
Unknown VRAM
10.18.10.3650
Supported Extensions not in OpenGL 3.3 (Version):
EXT_extensions_string
GL_ARB_base_instance (4.2)
GL_ARB_buffer_storage (4.4)
GL_ARB_compatibility
GL_ARB_compute_shader (4.3)
GL_ARB_debug_output
GL_ARB_gpu_shader5 (4.0)
GL_ARB_gpu_shader_fp64 (4.0)
GL_ARB_program_interface_query (4.3)
GL_ARB_robustness
GL_ARB_sample_shading (4.0)
GL_ARB_separate_shader_objects (4.1)
GL_ARB_shader_image_load_store (4.2)
GL_ARB_shader_storage_buffer_object (4.3)
GL_ARB_tessellation_shader (4.0)
GL_ARB_texture_buffer_object_rgb32 (4.0)
GL_ARB_transform_feedback3 (4.0)
GL_ARB_vertex_attrib_64bit (4.1)
GL_EXT_abgr
GL_EXT_blend_minmax
GL_EXT_direct_state_access
GL_EXT_texture_filter_anisotropic
GL_KHR_debug (4.3)
Unknown VRAM
10.18.10.3650
GL_ARB_debug_output
GL_ARB_robustness
GL_EXT_abgr
GL_EXT_blend_minmax
GL_KHR_debug (4.3)
WGL_EXT_swap_control
Unsupported OpenGL Extensions used by Houdini:
GL_ARB_multi_bind (4.4)
GL_ATI_meminfo
GL_NVX_gpu_memory_info
OpenGL Limits:
ELEMENTS_VERTICES 1048576
ELEMENTS_INDICES 1048576
VERTEX_UNITS 32
TESS_CONTROL_TEXTURE_IMAGE_UNITS 32
TESS_EVALUATION_TEXTURE_IMAGE_UNITS 32
GEOMETRY_UNITS 32
FRAGMENT_IMAGE_UNITS 32
COMBINED_UNITS 192
TEXTURE_SIZE 16384
3D_TEXTURE_SIZE 2048
CUBE_MAP_TEXTURE_SIZE 16384
RECTANGLE_TEXTURE_SIZE 16384
TEXTURE_ARRAY_LAYERS 2048
MAX_COLOR_TEXTURE_SAMPLES 8
MAX_DEPTH_TEXTURE_SAMPLES 8
FBO_ATTACHMENTS 8
DRAW_BUFFERS 8
VIEWPORT_DIMS 16384x16384
VERTEX_UNIFORMS 4096
FRAGMENT_UNIFORMS 4096
VERTEX_ATTRIBS 16
VERTEX_OUTPUT_COMPONENTS 128
MAX_CLIP_DISTANCES 8
PATCH_VERTICES 32
TESS_GEN_LEVEL 64
TESS_PATCH_COMPONENTS 120
TESS_CONTROL_OUTPUT_COMPONENTS 128
TESS_CONTROL_TOTAL_OUTPUT_COMPONENTS 4096
TESS_EVALUATION_OUTPUT_COMPONENTS 128
GEOMETRY_UNIFORM_COMPONENTS 4096
GEOMETRY_INPUT_COMPONENTS 128
GEOMETRY_OUTPUT_COMPONENTS 128
GEOMETRY_TOTAL_OUTPUT_COMPONENTS 1024
GEOMETRY_OUTPUT_VERTICES 256
UNIFORM_BLOCKS 70
UNIFORM_BLOCK_SIZE 16384
UNIFORM_BUFFER_BINDINGS 84
COMBINED_VERT_UNIFORM_BLOCKS 14
COMBINED_VERT_UNIFORM_COMPS 61440
TESS_CONTROL_UNIFORM_BLOCKS 14
TESS_CONTROL_UNIFORM_COMPONENTS 4096
TESS_EVALUATION_UNIFORM_BLOCKS 14
TESS_EVALUATION_UNIFORM_COMPONENTS 4096
COMBINED_GEO_UNIFORM_BLOCKS 14
COMBINED_GEO_UNIFORM_COMPS 61440
COMBINED_FRAG_UNIFORM_BLOCKS 14
COMBINED_FRAG_UNIFORM_COMPS 61440
MAX_FRAGMENT_STORAGE_BLOCKS 8
MAX_STORAGE_BLOCK_BINDINGS 8
TRANSFORM_FEEDBACK_INT_COMPS 128
TRANSFORM_FEEDBACK_SEP_COMPS 4
TRANSFORM_FEEDBACK_SEP_ATTRIBS 4
LINE_WIDTH_RANGE 0 - 6.99219
LINE_WIDTH_GRANULARITY 0.5
POINT_SIZE_RANGE 1 - 20
POINT_SIZE_GRANULARITY 0.125
OpenCL Platform NVIDIA CUDA
Platform Vendor NVIDIA Corporation
Platform Version OpenCL 1.2 CUDA 7.0.0
OpenCL Device GeForce GTX 770
OpenCL Type GPU
Device Version OpenCL 1.2 CUDA
Frequency 1137 MHz
Compute Units 8
Device Address Bits 64
Global Memory 2048 MB
Max Allocation 512 MB
Global Cache 128 KB
Max Constant Args 9
Max Constant Size 64 KB
Local Mem Size 47 KB
2D Image Support 16384x16384
3D Image Support 4096x4096x4096
OpenCL Platform Extensions:
cl_khr_byte_addressable_store
cl_khr_icd
cl_khr_gl_sharing
cl_nv_compiler_options
cl_nv_device_attribute_query
cl_nv_pragma_unroll
cl_nv_d3d9_sharing
cl_nv_d3d10_sharing
cl_khr_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
OpenCL Device Extensions:
cl_khr_icd
cl_khr_gl_sharing
cl_nv_pragma_unroll
cl_nv_d3d9_sharing
cl_nv_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_khr_fp64
Environment:
ACTIVETAKE Main
ADSK_3DSMAX_x64_2014 C:\Program Files\Autodesk\3ds Max 2014\
ADSK_3DSMAX_x64_2015 C:\Program Files\Autodesk\3ds Max 2015\
ADSK_3DSMAX_x64_2016 C:\Program Files\Autodesk\3ds Max 2016\
ALLUSERSPROFILE C:\ProgramData
APPDATA C:\Users\Robix\AppData\Roaming
CLASSPATH .;C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/houdini/scripts/java/sesi.jar
CM2014DIR C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\
CM2015DIR C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\
COMPUTERNAME ROBIX-PC
ComSpec C:\Windows\system32\cmd.exe
CommonProgramFiles(x86) C:\Program Files (x86)\Common Files
CommonProgramFiles C:\Program Files\Common Files
CommonProgramW6432 C:\Program Files\Common Files
FP_NO_HOST_CHECK NO
H C
HB C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/bin
HD C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/demo
HFS C
HH C
HHC C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/houdini/config
HIP C
Users/Robix
HIPFILE C
Users/Robix/untitled.hip
HIPNAME untitled
HOME C
Users/Robix/Documents
HOMEDRIVE C:
HOMEPATH \Users\Robix
HOUDINI_DESKTOP_DIR C
Users/Robix/Desktop
HOUDINI_OS Windows
HOUDINI_TEMP_DIR C
Users/Robix/AppData/Local/Temp
HOUDINI_USER_PREF_DIR C
Users/Robix/Documents/houdini15.5
HOUDINI_VERSION 15.5.570
HSITE C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/site
HT C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/toolkit
HTB C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/toolkit/bin
ILBDIR C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\
ILMDIR C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\
JOB C
Users/Robix
LOCALAPPDATA C:\Users\Robix\AppData\Local
LOGONSERVER \\ROBIX-PC
MOZ_PLUGIN_PATH C:\Program Files (x86)\Foxit Software\Foxit Reader\plugins\
NUMBER_OF_PROCESSORS 4
OS Windows_NT
PATH C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/python27;C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/bin;C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/toolkit/bin;C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Common Files\Autodesk Shared\;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
POSE C
Users/Robix/Documents/houdini15.5/poselib
PROCESSOR_ARCHITECTURE AMD64
PROCESSOR_IDENTIFIER Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
PROCESSOR_LEVEL 6
PROCESSOR_REVISION 3c03
PSModulePath C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC C:\Users\Public
PYTHONHOME C
ProgramData C:\ProgramData
QT_OPENGL_DEBUG_CONTEXT 0
QT_OPENGL_ENABLE_RETINA 0
SESSIONNAME Console
SystemDrive C:
SystemRoot C:\Windows
TEMP C
TMP C:\Users\Robix\AppData\Local\Temp
Number of Cores: 4
Number of Cores: 4
Unknown VRAM
10.18.10.3650
GL_ARB_debug_output
GL_ARB_robustness
GL_EXT_abgr
GL_EXT_blend_minmax
GL_KHR_debug (4.3)
Unknown VRAM
10.18.10.3650
GL_ARB_debug_output
GL_ARB_robustness
GL_EXT_abgr
GL_EXT_blend_minmax
GL_KHR_debug (4.3)
GL_ATI_meminfo
OpenGL Limits:
VERTEX_UNITS 32
GEOMETRY_UNITS 32
COMBINED_UNITS 192
TEXTURE_SIZE 16384
FBO_ATTACHMENTS 8
DRAW_BUFFERS 8
VERTEX_ATTRIBS 16
PATCH_VERTICES 32
TESS_GEN_LEVEL 64
UNIFORM_BLOCKS 70
OpenCL Type GPU
Frequency 1137 MHz
Compute Units 8
Global Cache 128 KB
Max Constant Args 9
cl_khr_icd
cl_khr_gl_sharing
cl_nv_pragma_unroll
cl_nv_d3d9_sharing
cl_nv_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
cl_khr_icd
cl_khr_gl_sharing
cl_nv_pragma_unroll
cl_nv_d3d9_sharing
cl_nv_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_copy_opts
cl_khr_fp64
Environment:
ACTIVETAKE Main
CLASSPATH .;C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/houdini/scripts/java/sesi.jarCM2014DIR C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\
FP_NO_HOST_CHECK NO
H C
PROGRA~1/SIDEEF~1/HOUDIN~1.570HB C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/binHD C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/demoHFS C
PROGRA~1/SIDEEF~1/HOUDIN~1.570HH C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/houdiniHHC C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/houdini/configHIP C
Users/RobixHIPFILE C
Users/Robix/untitled.hipHIPNAME untitled
HOME C
Users/Robix/DocumentsHOMEDRIVE C:
Users/Robix/DesktopHOUDINI_OS Windows
HOUDINI_TEMP_DIR C
Users/Robix/AppData/Local/TempHOUDINI_USER_PREF_DIR C
Users/Robix/Documents/houdini15.5HOUDINI_VERSION 15.5.570
HSITE C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/siteHT C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/toolkitHTB C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/toolkit/binILBDIR C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\
JOB C
Users/RobixLOCALAPPDATA C:\Users\Robix\AppData\Local
OS Windows_NT
PATH C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/toolkit/bin;C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Common Files\Autodesk Shared\;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\CommonPATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
POSE C
Users/Robix/Documents/houdini15.5/poselibPROCESSOR_ARCHITECTURE AMD64
PROCESSOR_LEVEL 6
PYTHONHOME C
PROGRA~1/SIDEEF~1/HOUDIN~1.570/python27ProgramData C:\ProgramData
SESSIONNAME Console
SystemDrive C:
TEMP C
Users/Robix/AppData/Local/TempTMP C:\Users\Robix\AppData\Local\Temp
