Change "width" attribute in a packed object
   1965   3   0
is there a way to change the “width” point attribute on a packed object without unpack it?
Edited by mzigaib - Sept. 22, 2016 18:30:19
https://vimeo.com/user2163076 [vimeo.com]
Anyone ?
I don't think you can change anything on a packed object unless you unpack it. If you control the packing of the object just set the width before you pack. You could also make a scene that unpacks, sets the width then repacks and writes that out as an Alembic or whatever format. Then your main scene can reference the alternate width adjusted version of the packed geometry.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Thanks dude!
