What is the $C variable?
   5350   2   0
I've tried using the feature of right clicking on a paramter ‘box’ and applying a motionfx.
In my case I used a noise and houdini dropped down a CHOP for that purpose.
However, I have my preferences set to Python and in this case as I have noticed it seems not all nodes have yet been ‘converted’ to scripting preferences.
What I mean is that some nodes have expression pre-sets in h-script but if your preference is python it will lay down a node with the h-script and not python version.
Because of this, in my chop there is a noise node that has a parameter called “Seed” with the expression red highlighted as $C.
I could just change the default script of that node back to H-script but I am interested in learning how to use python as much as possible.
I looked in the docks under the parameter expressions for what I am assuming is a global variable but can't find it.
Not knowing what it represents I can't search for the Python equivalent; like instead of using $F we can use hou.frame().
Maybe its not a global variable at all?
Thanks for any help.
$C in Chops is you current channel number.
Edited by sepu - Oct. 14, 2016 22:10:38
Cool, thanks sepu.
I guess that's considered a local variable then.
I'm thinking that because I just tried using lvar('C') and I get the same results as hscript with no problems.
