Viscous fluids and collisions
   3431   7   1
I'm having issues with viscous fluids not handling concave collision geometry. Imagine a flat tray shape, non viscose fluids fill the tray correctly but the moment I turn on viscosity I'm colliding with the bounding box with a slight bulge into the negative space. Ideas?
Have you set up your scene manually or via the shelf tools.
Rob
Gone fishing
I tried it both ways, same results
Hi See attached everything working . centos h15,5,565
Rob
ex_flip_viscosity_concave_v001.hip (1.9 MB)
Gone fishing
Post up your scene file if you want
Rob
Gone fishing
I'm taking a look at your file, here's the issue I'm having in the attached file
viscocityCollisionIssues.hip (2.0 MB)
Ive had a quick tidy up and all works as expected. Scene noted in green. The main clean was with your collision geometry vdb creation. The exterior / interior voxel banding of 1 is simply not enough to calculate the collision correctly especially when its tied to the particle separation value.
viscocityCollisionIssues_fixed.hip (2.0 MB)
Gone fishing
Got it, a thousand thanks!
