Twisted curve and sweep SOP
   6679   4   1
I have this problem with a twisted curve when I use a sweep operator. I see sweep sop it have Twist control, but I can't use it handly to fix this issue.
The curve is generated by a equation from wrangler, and must be a close curve. I've tried closing curve from code and with ends SOP.
I need have to control closing point of curve profile at start and at ends from sweep operator, else for curve rotation.
Captura de pantalla 2017-01-01 a les 20.44.58.png (1.4 MB)
It´s nicer to post a hip file.
Uploaded hip file.
I've seen the problem appears when the equation curve is heavy twisted. With a simple circle for example, works as expected when arc is closed in the same Circle SOP or keep arc opened, then using Ends SOP to close it.
I think in a way to control the ends up vector, but maybe there is a easy solution to keep a correct curve continuity respect its points orientation.
twisted_curve_wrangle.hipnc (78.2 KB)
I have tried everything and I get issues with the winding order, even after rebuilding the curve. Maybe revise how you create the twist and do that as a post created line effect.
Rob
rse_fixed_twisted_curve_wrangle.hipnc (117.8 KB)
Gone fishing
Thank you circusmonkey!
Using your method with Polyframe and copyOp instead SweepSOP tangent + normal attributes, it seems works ok. Using a open profile and close with SkinOP is valid for my purporse too.
After I've seen that it have a bit of twist in the ends of curve. However it's suitable in most situations of twist and divisions.
It would be possible add a value to an attribute?
I want to try adding a small increment to current normal to attempt compensate the current deviation.
Edited by Unaided - Jan. 3, 2017 10:44:03
fixed_twisted_curve_wrangle.hipnc (84.0 KB)
